FATMOON demo data (Florence) failed and destroyed whole wordpress build
in FatMoon Posts: 1
I've tried to import the demo data of the FLORENCE Theme of FATMOON several times, but each time WooCommerce is being installed the import failed and the wordpress build isn't reachable anymore (Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 12288 bytes) in /www/htdocs/w00d32c7/studiokoje/wordpress/wp-content/plugins/js_composer/include/params/animation_style/animation_style.php on line 86).
What is wrong and how could I change it?
Greetings,
Jens
    Hello there:-)
    I see on your screen shot that your server reports 256MB of memory. However it looks that it is faking this number, cause if you divide 67108864 by 1024*1024 (number if bytes in Megabyte) it equals to 64MB.
    It is first time I see such faking server. Please contact your server admin, so they will set it to real 256MB.
    WooCommerce plugin need some additional memory that is why 64MB in not enough and you get this crash. Theme and other plugins also take some memory.
