Hi!
Is there any way to set up the menu so that the subitems appear upon hover, and not on click?
I intend to use that first level as links as well, so therefore I need to make sure that the second level menu items appear when you hover over the first level item.
This is not possible, however we have solution for such scenario and it is explained here http://rifetheme.com/help/docs/customizing-the-theme/header/main-menu/
Hope that helps.
