Follow these steps: 1) Download the slider from my attachment 2) Go to your Slider Revolution panel and import that slider ( http://nimb.ws/Lt2onN ) 3) Go to your page http://audioception.com/roomcorrection/ , edit this page and add the Revolution Slider shortcode ( http://nimb.ws/Lt2onN ) 4) Remove the ROW with the "IT CAN MAKE OR BREAK A MUSIC SYSTEM.." text and that should be all
as you can see here.. it didn't work out http://audioception.com/alternate/ there is a space above and it doesn't fit. also the slider seems to go behind the menu on the left as well.
also while you are looking.. on every page there seems to be a large space between the top image and the first text block.. could you tell me how to get rid of that please?
Right now the best way is to clone this specific page and replace information from other page's because i had to change the structure of your VC blocks and some page settings.
Thank you i really appreciate you doing this so quickly... I noticed there seems to be a heavy border on the left and right.. does it have to be that deep?
You would have to import demo content of demo 6 & and after clear what you don't need.
If you want just Revolution Slider form this demo then you can import just sliders when using importer.
Follow these steps:
With Regards
About your last question, you need to change the top and bottom paddings: http://nimb.ws/jtkiJP
With Regards
You can download and install this plugin https://wordpress.org/plugins/duplicate-post/ and just duplicate this page and on the end replace it with your existing pages.
At first, it may seem like a bit of work but it will be easier in later stages.
With Regards
Like I wrote in the previous comment I had to rebuild this page: http://audioception.com/alternate/ for the Slider Revolution. Like you see in the screenshot I added two columns: http://nimb.ws/2TMxPm
You can rebuild this by adding smaller width. Open each column and add these settings to the Responsive tab: http://nimb.ws/Cb37Sn
Remember that you must rebuild all ROW's
With Regards
