Submenus appear right under header bottom edge. When you have one row of menu options it looks right. In case of more rows, it may make sense to move it up, but then there is a chance that it will cover other main menu options, what is also not desired.
Another thing is that most people try very hard to not have more then one row of menu options, cause it just looks bad.
This was an interesting issue; I personally do not use more than one row of menus, but someone might bring it up in the future if they decide to use more than one row.
What do you think?
