Read more problem
Hi !
Since the last update, I have a "Read more" which appeared on my blog list.
I don't use the "more" tag, but the excerpt to customize it. I would like to remove it, cause the images size were perfect with the titles, and now it too big.
Thank you !!
Sophie
    Yes we recently found out that there is no call for read more when excerpts are used. It is usually bug. However I understand your situation.
    Add this in your functions.php in child theme, and I will think about some option for this in theme:-)
    add_action('after_setup_theme',function(){
        remove_filter( 'the_excerpt', 'apollo13framework_has_excerpt_read_more' );
  • It works like a charm ! Thank you so much ! :)
