Hey,
I installed a plugin to integrate my mailchimp account with a custom form, however the form uses its own custom styles - which I do not want!
Please can you tell me where the custom CSS is located for forms within FatMoon?
I will then copy and paste this into my custom CSS file which should do the trick
Thanks,
Samuel
Often in such plugins there is option to disable their custom CSS. Please tell me name of plugin, and I will look if there is option to disable it.
I located the form CSS in the editor panel and pasted it into my custom CSS which seems to have overridden the plugins CSS.
Thanks for info!
