It initially looks OK, but when you click on an image, it doesn't open in fullscreen. When you close the picture down again, the pictures seem to have a large gap inbetween them.
OK, I have seen your scorller. It works fine for me.
Scroller doesn't open images to full screen, but only stretches them when clicked. So if you would like more full screen experience then you would have to add scroller with window_high parameter.
In other case if you want to add images with opening to ligthbox , then I would recommend using use Images from Elementor or Image gallery from elementor with option to open in lightbox.
If you want to use this element, that we called scroller, on page instead of album you can add it as shortcode http://rifetheme.com/help/docs/content-management/shortcodes/scroller/
I'm having issues creating the scroller with the same effects as you guys have on yours.
https://metexmedia.com/om-os/ (it's in the bottom)
I hope you can help.
Best Regards
Sure, when your coming soon mode will be deactivated ;-)
window_high
parameter.In other case if you want to add images with opening to ligthbox , then I would recommend using use Images from Elementor or Image gallery from elementor with option to open in lightbox.
