Proofing Gallery customization
in FatMoon Posts: 60
And another another one.
1. How to get rid of icons "Gallery List" and "Next Gallery" on the left side of images? As that's no client's business :] I ticked in the Album settings "Exclude from Albums list page" to Enable, but that did not change things.
2. Also, where can I set custom Password page?
It's Friday, I know ;]
    OlafsOsh said: It's Friday, I know ;]
    Haha Hi there:-)
    OlafsOsh said: ow to get rid of icons "Gallery List" and "Next Gallery"
    Appearance → Customize → Albums Settings → Single album – bricks → Albums navigation → Disable
    OlafsOsh said: 2. Also, where can I set custom Password page?
    Read here http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/page-settings/passwords-protected-page/
    Awesome! Did I need to find it by myself? Sure.
    Anyhoo. Is there [I really searched!] way to customize the look of password input field and that button?
    Also!
    I am losing the Menu visibility. Where did I need to change that? :disappointed:
    https://olafsosh.com/album/yadayada/
    There isn't much settings for input, hover button should fall under general buttons settings http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/buttons/
    About input if you tell me what you would like to change I will try to help. I also have in my "to do" some customization option for this form, but I am not yet there, as it is niche need ;-)
    OlafsOsh said: I am losing the Menu visibility. Where did I need to change that?
    Try changing header color variant in page that you have created for password page.
    Or disable this feature if you don't need more confusion ;-) http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
    Menu fix worked awesome - just am not used to the thing, that I can manually change settings per page. My mistake.
    As for button - I have no idea where that blue color comes from... Not defined in Button section, that's for sure :D
    As for design - you know - not so bulky. Like in attachment. with one line and a cursor blimping, that kind of stuff.
    1464 x 899 - 517K
    Hey there :-)
    As for button - try setting value for hover color of buttons once more, cause I can see there is some error in generated CSS.
    As for input - I would be cautious with such designs, cause depending on user device, such input will get lost on photo in background + such design is not accessibility proof, so I would not recommend it if you don't want to frustrate some of your visitors ;-)
    I can help more in moving it a bit lower or making it bigger.
    Think about it and lets talk tomorrow:-)
    Right... OK. That worked :D I'll do that from no on - just re-save things first.
    As for that second thing - naaah, large thing will be even clumsier - let's leave it as it is then. With not so round corners it looks less childish - will suffice.
