Album background color and controls in Fatmoon
Hello
I can not get the background of my albums to turn white.
I also want to remove the counter and loading screen.
I have them set to off in the customizer but they still appear. I have emptied cache several times and still nothing.
http://w7o.cc9.myftpupload.com/
    If you mean this black background color then go to Appearance → Customize → General settings → General Layout -> Boxed layout background color.
    tmillions said: I also want to remove the counter and loading screen.
    Can you tell me where you did that, cause I don't think we have such setting?
    I will get back to you tomorrow as I am leaving office for today:-)
  • The color worked! Is there a way to hide the counter and buttons in the bottom right?
    Just add this custom CSS and they will not appear anymore:
    .slider-controls{
        display: none;
  • That worked thanks!!! Do you know where I can change the button color from blue? I have looked everywhere. It is on click. thanks!
    1413 x 731 - 322K
    Go to Appearance → Customize → General settings → Buttons and set Hover color for buttons. I see there is wrong value set currently, so you will have to adjust it.
