I want to create a landing page with your parallax slider. The site should have content under the slider. I got it now with the shortcode [a13fe-scroller id="8451" autoplay="3" window_high="1" texts="0" parallax="1"] However, it destroys the slider when I click on a picture.
Can I fix the error somehow? Or is there another way to do it?
Could you show me link to your site so I could better understand what you mean by "destroying slider"?
the link https://novski-fotografie.de/new-home/
Everything works fine. Click opens photo for view. With clicking again it reverts. You can still scroll scroller when photo is opened.
See our demo http://rifetheme.com/photoproof/ :-)
If you would like to disable it, then currently there is no option to disable opening. However maybe you have idea how you would like to enhance it so it would be more clear that nothing is destroyed?
I can recreate issue on your site when I view it on Chrome browser, but I can not do it on my installation.
I see you have older version of theme. Could you try to update it to newest version http://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/
I am not sure it will fix issue, but then one possibility will be ruled out.
And then another question. On the mobile device the slider is showing complete text. http://rifetheme.com/photoproof/about-ii/ Can I show only one sentence on mobile?
Sorry for so much questions
In case of text you can edit it in translation http://rifetheme.com/apollo13-framework/docs/translations/translating-theme/ if you really need to. We tried to make this button not disturbing too much, and it only shows if user was not scrolling scroller for 5 seconds at least.
As for color, you can use this custom CSS: What you mean by slider? This big image at top? I don't think you will be able to hide rest of text easily in WPBakery, but I will ask Daniel to take a look at your case. But please explain do you mean this image or something else:-)
Yes, you must explain it better like Air wrote
With Regards
And sorry for my bad english XD
Other choice would be to use custom CSS to hide other sentences: With kind regards.
