Two questions
in Rife Posts: 33
Hey again,
I'm trying to create a page like the one you have here: https://rifetheme.com/east/album/gallery3/
However, I would like to not have the different categories at the top and the sidebar should be gone. Additionally, the page it should be on is https://metexmedia.com/cases, so I can't use the direct album link. Is this possible?
The other question I have is: How can I make submenus drop down in my main menu?
I've set it up as per the attached screenshot. Perhaps I'm missing a setting somewhere. I've looked in customize.php, but I can't seem to find a place where submenus are enabled.
I've also looked through this page https://rifetheme.com/help/docs/customizing-the-theme/header/main-menu/
but even with mega menu enabled, I can't get it to work.
What I want to do is have "Løsninger" open a page if you click on it. If you just hover it, 3 subitems should appear underneath it that each open a different page. I hope you get what I mean.
I appreciate the help. Thanks in advance!
    metex said: Additionally, the page it should be on is https://metexmedia.com/cases, so I can't use the direct album link. Is this possible?
    Currently there is no option to display bricks album outside album or work. This will be added in one of upcoming versions. So currently - not possible.
    metex said: What I want to do is have "Løsninger" open a page if you click on it. If you just hover it, 3 subitems should appear underneath it that each open a different page. I hope you get what I mean.
    There are none "hover subemnus" in Rife theme. They are only opened by click. You can read more in page that you have already read in part Submenus https://rifetheme.com/help/docs/customizing-the-theme/header/main-menu/
    To show option to open submenu please be sure to setup submenu openers. You can activate it in Appearance → Customize → Header Settings → Main Menu → Submenu/mega menu open icons
    So all is explained in page that you have cited ;-)
    Air said: Currently there is no option to display bricks album outside album or work. This will be added in one of upcoming versions. So currently - not possible.
    Ok, that's fair. However, I still cannot get https://metexmedia.com/album/cases/ to work. It just gives a 404 page despite being the correct link according to the album tab. Am I doing something wrong?
    Please refresh permalinks as explained here https://rifetheme.com/help/docs/basic-setup/permalinks/
    That worked. Appreciate the help as always.
    Happy Easter :smile:
