Apollo13 Framework Extensions and problems with the works section
edited April 2018 in OneLander Posts: 14
Hello guys,
after installing the plugin update in question and having it removed as you suggested in another post. I reinstalled the previous version of the framework and now the worklist is displayed correctly but when I click on the work item the error 404 is displayed. In practice it is as if the works are not there .... even if in fact categories, works and everything it's in its place.
An update is urgently needed ...
thank you very much
Post edited by merlino71 on
    Hey merlino!
    Please refresh permalinks https://rifetheme.com/help/docs/basic-setup/permalinks/
    Sorry for the issues - it was really not intended to go this way.
  • edited April 2018 Posts: 14
    Hey Air!
    ok, work fine. but the videos from the library in works section continue to not play
    I hope you can do something to solve it.
    Thank you very much
    Yes, I am working on it right now, and will release update soon(today). Give me some time, as this "Apollo13 Framework Extensions" hell broke out during weekend :-)
