I cannot update the theme " Update package not available.."
edited November 2012 in Hypershot Posts: 60
    As this is commercial theme there is no automatic update for it. We will try to solve it in future but for now you have to download new version from themforest and follow http://apollo13.eu/docs/hypershot/#!/installation_update_update_theme
  • And ? restart all the customization ?
    Explained in documentation. If you made changes in code, then yes you will lost it unless you followed documentation. If you mean settings in theme, you will not lost just need to recreate file as explained in documentation section about update.
  • And Where do we download the update ?
  • where do we find the link for update then ?
  • Ok ! I got it ;-) 1.0.1
  • edited November 2012 Posts: 2
    Where were you able to locate the zip file containing to update to 1.01??? Cant find it anywhere - do I just need to download the theme again assuming it's the updated version?
    Post edited by huberjohn on
    Yes, themeforest always have latest update and it is only place where you can locate it. I see I didn't wrote clear about it in documentation. Will fix it ;-)
  • Thank You for your reply!
  • Where can I find the documentation, with the new location of 1.01? :) Thanks
    You have documentation in your theme above every Hypershot setting, and also here http://apollo13.eu/docs/hypershot/
