hello
I come back to you because I encounter a problem following the last two updates of the theme.
All my plugin and the theme are up to date. On my homepage the bug menu icons when "WP Google Maps" is activated. (
http://bushcraft-mercantour.fr/wp-content/uploads/2018/04/Capture-d’écran-2018-04-10-à-10.34.29.png)
What is your problem exactly? I can not view your image cause of special character used in URL. Could you upload it again without those characters?
Is this also happening when you are not logged in to your WordPress?
Maybe it is cache issue, if you are using any plugin for cache?
I delete from the home page the map of "WP google maps" plug.
I replaced with a map google standar (without animation and flitre it's a shame).
To reproduce the bug it would be necessary to put a shortcode of the map WP map google in place. No I do not use cache plugin.
Could you send me shortcode and exported map you have inserted there. Maybe then I will be able to reproduce this issue?
