Hi again)
Thanks for your help!
And now is a questions:
1. How can I increase a line spacing between menu paragraphs?
2. How can I change the position of this par.? Now they in the center of menu and I want to put them upper.
3. When I go through the menu into sub menu then after going to the page I want - sub menu is close. I think it would be better to see on what page I am. Especially if there's no title on page.
I see you use vertical header on your site what is very important to help you:-) Go to Customizing ▸ Header settings▸ Type, variant, background ▸Variant ▸Clasic
Please use(and adjust) this custom CSS: This is not perfect solution, but please use this custom CSS: Meanwhile I will think how to add this from theme settings.
If possible, write please CSS for "line-height" of sub-menu par.)
Try this: With kind regards.
How can I change background color for menu on mobile devices?
And I want to change the size of hamburger icon.
Thank you for your job!
Appearance → Customize → Header Settings → Type, variant, background → Mobile menu background color. Please go to:
Appearance → Customize → Header Settings → Tools icons - individual icons → Mobile menu button icon size
