Some time ago, I upgraded two sites I had with Hypershot, to Rife. They are simple portfolio sites, nothing very complex. Since a couple of updates of the theme ago, I am getting 508 error on both very often. I have two Photon sites too also with same hosting and they are not having that problem. These ones are a little more complex (more plugins)
The 4 of them have more or less same config for cache, security, etc., so I think Rife theme has something to do. They are not sites that have a lot of visits.
Any idea how I can fight the problem? (Apart from upgrading hosting, what I do not consider necessary)
Thank you
I suspect it can be something connected to resources. However, it would be best to ask your hosting provider what error 508 mean on their server and when does it happen.
Also be sure to use Rife theme in the version at least 1.7.0 as it uses much less memory https://apollo13themes.com/apollo13-framework-themes-free-redux-framework-plugin/
