Black Bar Under Menu
in FatMoon Posts: 1
Apologies if this has been asked - I tried to search keywords and documentation but couldn't find anything similar.
There's a horizontal black bar that extends slightly beneath the menu in a page I'm building, though it doesn't go to the edge of the screen. I'd like to remove the black bar (I'm comfortable with using a different template for the page if that's what's needed, but I do like the current template so figuring there's got to be a way to just remove the bar).
Hoping someone has a fix for me!
