Hi!)
I installed WPML plugin. Set language switch. Put it in footer.
On desktop version - all is OK.
On mobile version I can't see it. I want that in the mobile version the language switch is under the menu icon in the center of the screen. It can be done?)
You can check it: gotovyy.com
You have placed your language switcher in footer widgets that are hidden on mobile when using the vertical header. I think it would be better to use language switcher in menu - this way it will be available on mobile also.
If you like I can then help you to hide this "sub-menu" on desktop so it will be only visible on mobiles/tablets/smaller devices. Then you will have you cool language switcher available on desktop/big devices.
I think it would be better do not use widgets. Help me to place language switch in menu (desktop) but on the same place as right now.
For mobile, if it is possible, I want as on attached image.
Thank you)
I think you didn't understand me.
I meant to add the language switcher to main-menu, so it will be part of your main menu, and cause of this it can't be moved from it(like on your screen shot). See http://rifetheme.com/apollo13-framework/docs/translations/translating-site-with-wpml/language-switcher/
What I offered is:
1. On big devices(above 1024px) user will see your current language switcher from widget, and switcher from main menu we will hide with CSS.
2. On small devices widget is hidden, so we will show again language switcher from main menu.
Once you will add it, I will prepare custom CSS for you.
As each language is separate menu item, they can't be displayed one by one, unless you will make such modification in theme code/CSS. However this modification is beyond support forum.
So it would work a bit different then you imagine, like this:
In WPML setting switch to "Vertical structure" to achieve this:
This way it could be displayed more closely to what you have imagined. I will add it to my TODO list.
I added, but still have both switchers on desktop.
And still have something like footer on mobile (look at the picture)
Add this Custom CSS to hide "menu" switcher on big devices: Sorry my bad here, I have updated CSS now. Please use updated code instead.
On hebrew version "to-top button" should on the left side)
I don't see any attachment, but like I said FatMoon theme is not RTL ready yet.
However, after we will finish all stuff concerning GDPR, I will look into some basic RTL changes.
