Rife General Settings: After setting Wordpress Adress url page jumps instead of scrolling
edited May 2018 in Rife Posts: 17
I've build a onepage website that was working well until I've set the Wordpress Adress url to final domain. In the general settings these settings where greyed out so I had to take care of them in the wp-config.php, setting them to:
define('WP_SITEURL', 'http://matus-burritos.com');
define('WP_HOME', 'http://matus-burritos.com');
However, while previously (just having the hosting IP set for those values) the scrolling between section was working well. Now my website fully reloads each time I use the menu and afterwards simply jumps to the choosen section.
I am a bit lost. Any ideas?
Thanks & kind regards,
Thomas
Post edited by KleinesPony on
    Hey Thomas :-)
    I have just checked it on my FireFox and it works fine for me. Do you still face this issue?
    If yes, then please if you see it when you are not logged into WordPress.
    Hi Air,
    thanks for your feedback. Yes, I moved to a different hoster which solved this issue.
    Thanks for info!
    Good luck with your site:-)
