Exclude Category from Filter in work
I would like to exclude a category and work from that category from the filters in the work section. Was not able to find the setting for the same. Would you be able to help me with this? Attached screenshot for reference.
    edited June 2018 Posts: 10,970
    Hey there:-)
    Edit your page with Elementor and edit shortcode for work list. Then add category attribute, and list all categories that you want to use. Examples you can find here https://rifetheme.com/apollo13-framework/docs/content-management/shortcodes/post-list/
    It will look something like this
    [a13fe-post-list type="work" orderby="title" posts="5" columns="2" category="people,nature,logo" filter="1"]
    Hope that helps :-)
  • edited June 2018 Posts: 6
    Thanks, that worked! :)
    Post edited by apmonisha on
