Elementor pro footer function not working with theme
Good day,
I have a Elementor Pro license and was trying to replace the footer inside the Photoproof theme.
However, when i am running Elementor Pro and have the footer created, it turns off the header and makes the whole page dark.
I then reverted Elementor and Elementor Pro back to the old version where it was unable to do headers / footers and the problem was gone.
However, is it possible to get the Elementor footer working with the rest of the theme?
  • I played around with it even more, once i set the footer to no display conditions (basically take it off every page) the theme header comes back and everything goes back to normal.
    I am also putting every page on "default template" as i have referred to other threads similar to mine.
    Hey there:-)
    Personally, I haven't played with Elementor Pro Footer/Header feature. In the last version of the theme, we have added support for a plugin that was used for this before it was implemented in Elementor Pro.
    You can read about it here https://rifetheme.com/apollo13-framework/docs/plugins-recommendations/header-footer-elementor/
    As for this new feature - I will have to check it how it works to give you a precise answer.
    I will not be able to test it today, so I will reply tomorrow probably.
    darrenho97 said: However, when i am running Elementor Pro and have the footer created, it turns off the header and makes the whole page dark.
    darrenho97 said: I am also putting every page on "default template" as i have referred to other threads similar to mine.
    Yes, canvas mode disables all theme features like explained here https://rifetheme.com/apollo13-framework/docs/plugins-recommendations/elementor/elementor-canvas/
    As for using the Elementor Pro custom footer feature:
    They advertise it as working with any theme. I have followed instructions from this movie
    Look at 1:00 before they refresh the page - you will see there is theme header & footer from The Twentyseventeen theme. After refresh, there is no header & footer.
    I must say I am not impressed by this. It looks like that any page that uses these custom header/footer from Elementor Pro is automatically displayed in canvas mode, which as you know, disables some of theme features & styles.
    Maybe better try "old" way https://rifetheme.com/apollo13-framework/docs/plugins-recommendations/header-footer-elementor/
    Anyway - you know that PhotoProof footer is constructed from widgets? So you have a lot of customization options.
  • Hi there. Tried to use the Header Footer Elementor plugin as an option, but its not appearing. Is it still supported?
    What exactly did not work? Header or footer, or both?
    Have you disabled theme header & footer in theme options?
  • What I'm trying to achieve is - Header used from the theme, footer used from the plugin.
    I didn't know that you had to disable both.
    The problem occurred when I tried to use the footer from the plugin, the page will turn grey and the theme basically gets messed up.
    Is the way that i suggested above possible to be implemented?
    You don't. I just asked did you switch off what you wanted to change(footer in this case).
    Be sure you didn't mark option " Display Layout automatically on Elementor Canvas Template? " as it switches off most of the theme parts.
    Read more about what canvas do https://rifetheme.com/apollo13-framework/docs/plugins-recommendations/elementor/elementor-canvas/
    Just as an update - since version 2.1.0 of theme there is officially added support for Elementor custom headers & footers. Big thanks to jasonser for helping with tests!
