Documentation for Starter Theme
in Starter Posts: 15
I am trying to read the Documentation for the 'Starter' Theme as an Htm file... but it is missing the Stylesheet for this so I am just seeing basic HTML text. IT doesn't make following the documentation easy as I don't see corresponding Images/screenshots et al. Can someone please help?
    edited July 2018 Posts: 10,970
    Valid documentation for the theme is here https://rifetheme.com/apollo13-framework/
    Thank you for this response. It was helpful. I have another question. I have imported the Demo that I wanted to use from the 'Design Importer' or theStarter theme. The Design that I wanted to import with all the Demo Content et al is from the Starter Theme. The Page is called 'STARTER 4' (https://rifetheme.com/starter-4/).
    I discovered in doing so that not all of the Content of that page was brought in. I am not sure if this has anything to do with the fact that I need to upgrade to the latest version of PHP 5.6... which I am in the process of doing. I have requested this to be provisoned by my SP. The site in question is:
    http://intertradinginternational.giveitaface.co.za.
    I only have the upper half of the page and it is giving me a '404 error'. Not sure what I missing here.
    1902 x 922 - 825K
    Hard to tell what could be happening in this case.
    Could you please send me temporary access to your WordPress so I could check there what is going on? Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
    I will do. Could I post all these details here as part of this thread between us/
    So what I did:
    1. I have updated the theme.
    2. Updated bundled plugins(mainly WP Bakery)
    3. Changed page selected as the front page, cause it was pointing to deleted by you "Sample page" that is why you had 404 error.
    You probably didn't do a full import with the remove of current content https://rifetheme.com/apollo13-framework/docs/installation-updating/importing-designs/importer-configuration/ and that is the reason for many issues.
    Now you should be able to move on.
    However, Revolution Slider didn't import images for its sliders, and I think it can be connected to an old PHP version, but I am not sure for 100%.
