Really ? Well, I don't want you to modify your theme just for me ! Do you think I can add some php lines on works-template.php, or is it too complicated ? (If it is, I will ask to a dev, cause I need this function in about 12 days : It will be a part of my main course, so the students can as questions beside each exercise).
Hard to say, it can be a quite wide modification, as it may require to edit plugin for custom post types also. I could test it tomorrow.
However, maybe a better idea would be to use Pages? They have comments, that can be turned on/off per each page. You can also arrange them in hierarchies.
Pages also have much more flexibility in my opinion.
With my subscription system and the organisation of courses allready existing, it would be a struggle to use posts or articles. I can only use albums or works, and I like the way it displays also, with "following" and the small grid to go back to the list.
So let me know if you found a way ! Thank you very much for your time.
2. Modify theme function in advance\utilities\cpt-work.php line ~93. Under this
<?php echo wp_kses_post($meta_content); ?>
</div>
add this code:
<?php
// If comments are open or we have at least one comment, load up the comment template.
if ( ( comments_open() || get_comments_number() ) ) :
comments_template( '', true );
endif;
3. Be sure to enable comments is work
One requirement for this to work: you have to have any text content in your work.
You are the first to ask about it:-)
Currently, there are no comments for albums & works. I will add it to feature requests.
Thank you !
Sophie
Do this:
1. In child theme, in functions.php add this This enables comments support for works.
2. Modify theme function in advance\utilities\cpt-work.php line ~93. Under this add this code: 3. Be sure to enable comments is work
