Adding Works list is same process as described here below, but you chose Works list template instead.
Do it exactly the same as for Albums list, but just change "Albums" with "Works" in that process.
As said in documentation https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-albums-list/ : With kind regards.
Want to thank me with coffee?
