RIfe. Work List Items Not Show when logout
in Rife Posts: 38
Hi Air or Daniel
- I have a PAGE where I added a section of Work List with 2 items
- It show 2 when log in, but only shows 1 when Log out.
- See 2 Screenshots attached. 1 login and 1 logout.
-Here the link:
http://wordpress-122203-569942.cloudwaysapps.com/outdoor-speakers-wall-mount-speakers/
Please advise.
Jason S
    I suspect one of 2 things:
    1. A cache plugin is not displaying your new works
    2. You have not published your new work. It is private or the draft.
    Please check it.
    Hi Air.
    - You are right! I reset the Cache Plugin and the items show. :)
    - Another question which my client had been asking. When we just visit the home page, there these white spaces on both sides of the page before it loads the content. Anyway we can change that white space to black or any dark colors?
    You can checked the attached Gif I took.
    Cheers
    Jason S
    1440 x 900 - 7M
    Think the Gif not working, so I re-attached a screen shot instead.
    719 x 450 - 45K
    Try setting page background to black in page options https://rifetheme.com/apollo13-framework/docs/content-management/pages/pages-options/
    Should do the trick:-)
  • HI Air,
    I tried as you success, but the white still happened.
    Just to clarify, the white space came in a "flash" when loading, before the Revo Slider and other content kick in.
    I had also tried...
    - changing the back ground on the top section
    - adding a background via Revo Slider
    - changing background via "Customize" on Page setting.
    Pls advise further.
    Cheers
    Jason S
    In this case, try with Content background in Appearance → Customize → General settings → Content styles. If this will also not help, then please send me a link to the page where I can see it happening.
