Hi, The revolution slider gives the following error when I want to use a Vimeo video: Vimeo Froogaloop Api Could not be loaded ! Please Check and Renew SSL Certificate ! How can I solve this?
What this case has to do with Vimeo? ;-) Next time please start a new topic.
It seems your server has outdated SSL verification, and that is why it doesn't recognize our SSL certificate.
Please try again, and if it will not work, you can always download these plugins manually from URLs that you can see on your screenshot, and install updates manually.
In theme I have corrected this few versions ago, however I am not 100% sure what is the situation with Revolution slider
I suppose you have to update theme and revolution slider to get secure versions of script.
To update please follow:
https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/manual-theme-update/
and
https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/
Please see attached the error I got when I update the plugins..
Any idea how to solve this?
Best, Luc
