Discussions
Categories
Home
Rife
Apollo13 Framework Extensions 1.5.0
meirinha
October 2018
in
Rife
I update the Apollo13 Framework Extensions plugin, and the site doesnt work more
Air
October 2018
0. Do you use a modified child theme?
1. Have you updated the Rife theme as well?
2. What is your PHP version?
3. Do you have access to your PHP error log on your server?
meirinha
November 2018
0. No
1. Yes
2. 7.0
3.yes
Air
November 2018
1. Can you paste here what PHP error is produced on a plugin activation?
I believe it could be a conflict with some plugin, but I need more info.
meirinha
November 2018
you are right, thanks!
Is the Power-Ups for Elementor plugin that is in conflict with rife theme.
Air
November 2018
Thanks for info! I will check it out to see if there is anything that I could fix from plugin level.
Air
November 2018
OK, I have found what can be improved on theme level. Plugin overwrites themes version of Isotope library and it results in JavaScript error.
In the next update, there will be fallback for such situations.
Thanks for your help.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
589
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
November 2018
meirinha
November 2018
Air
Discussions
Categories
Sign In
1. Yes
2. 7.0
3.yes
