Elementor Slider Shortcode on Side Bar Issue on Default Template
in Rife Posts: 38
I had paste the short code on an elementor slider on the side bar of a Post.
But the slider won't appear if I set the template as "Theme Default", it only shows the shortcode [elementor-template id="14136"] instead
See link here: https://www.drchoice.life/elementor-12909/
Slider suppose to be on top right of the side bar under the search bar
It will only appear if we set a "elementor template" with a side bar, and set it as Elementor Full Width.
I wonder is it a "Theme Default Issue" or simply Elementor issue
Cheers
Jason S
    What is the name of the widget you are inserting this widget in? Not every widget is parsing shortcodes.
    Please try "Shortcodes" widget.
  • Hi Air,
    Yes! Your are right !(again!!!).
    I used the regular html instead of the "short codes" widget.
    Thanks. :)
    P/S: will be upgrading as agreed with Daniel soon. Will keep you posted.
    Jason S
    Great that this is solved :-)
    In case you wish to upgrade, please contact us via e-mail :-)
