Hi :-)
1. On the retina 5k page
http://kotniz.eu/2019 have black marign on the left and right side, not full width. Screen one the Attachment.
2. On my album I need to have three property after clicking on the brick:
a) link to another page (it works)
b) and some brick that the click does not work (so that the photo does not grow)
c) video on lightbox
This may come helpful in future https://www.take-a-screenshot.org/ :-)
You can increase max-wdith of gallery by editing album that you are using on your front page. https://rifetheme.com/help/docs/content-management/albums-works-post-types/album-options/
Go to Album details -> Album Media -> Max width of bricks content. max value is 2500px but you can enter higher value by hand if you really need to.
Do you want to have all those 3 different actions on single brick? That is rather not possible.
If you mean that you want these actions on other bricks then it is rather tricky as you want lightbox and don't want it at the same time ;-)
For "and some brick that the click does not work " I would add custom link for this photo with empty anchor "#"(just hash). Put it in Link option.
As for "video on lightbox " - add your video, and add its Video Thumb - https://rifetheme.com/help/docs/content-management/albums-works-post-types/album-media/#youtube-vimeo-video
In theme options in customizer, be sure to disable displaying videos in bricks: Appearance → Customize → Albums Settings → Single album – bricks → Display thumbs instead of video → Enable.
Hope that helps.
But empty anchor "#" solves the problem only partially, because when i under the brick the mouse cursor (hand icon) suggests that I can toutch it - should not.
pointer-events: none;to the previous CSS then again cursor for clicking will appear, as it is set on an element on the layer below.Either allow people to open photos to lightbox, or go on with the current solution.
To make it work as you wish It would require to create a new option to disable photos opening to lightbox in an album exclusively.
As for cost - we don't do custom work. We try to help in range what is possible with the theme.
Problem is that is probably getting out of range for what albums were created. Adding such option to the album doesn't serve a purpose of albums :-)
I have one more idea!
You have links, videos, and photos that you don't want to open to lightbox.
Thanks to this special case, we can try such custom CSS: Add this instead of the previous one.
