I'm trying to get my 404 page to show up without the site header as I made a custom one for the page. I'm thinking there's got to be something within my 404.php file that might be overriding my 404 page's code.
Example of a link that goes to the 404 page where my transparent header shows up on top:
https://elogiclearning.com/category/increase-productivity/Anyone else run into this and figure out a solution?
Btw, I'm using the Rife theme.
To remove header for 404 page best would be using add such code to functions.php file Should fix your issue right away :-)
Screenshot attached.
It should hide black 404 at the top.
