How to move category navigation Position to top of single album view.
Hi, hope I can find a solution of the following visual issue:
1. My albums have no content so I had to hide the content column, however by doing that I hide the navigation which I need in order to get back to album list of next album. If I show the content column with the nav. only I get this very large white empty space which does not looks good.
2. Since I'm here I would also like to address the following issue regarding the album title. On global album settings, if I enable album title bar, the title will appear on all active albums. I need the album title bar on the portfolio albums but not on my homepage scrolling album. I looked in single album settings and I could not find an option to turn album title On/OFF
Thank you
    1) It is a good call. I will try to introduce album navigation that is more like in the works.
    See here under content https://rifetheme.com/rebro/work/photo-frame-mockup/
    However, I can not tell in which update it will be.
    edrio said: I need the album title bar on the portfolio albums but not on my homepage scrolling album. I looked in single album settings and I could not find an option to turn album title On/OFF
    Indeed there are no special settings for title per album.
    In this case, I would suggest adding your album as a gallery to your homepage instead setting it as an album.
    To do it:
    1) Create new page and set it as the front page https://rifetheme.com/apollo13-framework/docs/basic-setup/front-page/
    2) Add your album that you currently use as the front page as gallery/slider/scroller using Elementor widgets https://rifetheme.com/apollo13-framework/docs/content-management/elementor-widgets/
    Hope that helps :-)
    Thank you for the quick reply.
    1. Hope you can implement it soon, meantime users will have to click on the portfolio menu or go back using the browser.
    2. Your solution worked.
    Thank you!!
    New positions for Albums Navigation are added in version 2.3.0. It should be released next week.
    WIth kind regards.
