Hi ho and merry christmas to you all,
I'm sure, my problem is really simple, but I can't find a solution.
When I'm creating a blog post with a gallery, the pictures opens in a fine gallery lightbox. Sometimes I put only a single picture in the text and I would like to have the same lightbox for a single picture. Creating a gallery for this picture isn't a solutution, because I'm not able to align a gallery inside a text block. Would have I to do so a aligned picture inside a textblock opens an lightbox like the gallery?
Thanks for help!
Best wishes
Christian
If you have theme in version at least 2.0 you will have such option Customizing -> General settings -> Lightbox settings -> Use theme ligthbox for images in posts.
Enable it and it will work. Just be sure to make small photo link to Big file(Media file option).
Ehm..... this was toooooo easy! Sorry, I had overseen this option while looking around :-(
It works :-)
Thank you very much for your fast support and for this fantastic theme! Have a good christmas time and don't work too much ;-)
Best regards
Christian
It was good to take some rest during Christmas, hope you have rested some as well :-)
As for this feature - don't worry that you have missed it, as it was added in version 2.0.0.
