Hi, hope you're well! My home page is based on an album with a slider display. If you look at my site (
https://www.redwoodphotography.co.uk) on a mobile (e.g. iPhone 7 or 8), the image scaling doesn't seem right; the landscape images are at the bottom of the screen with a big space above them, and for the portrait images you have to scroll down to see them. Shouldn't the images scale to fit the display size like they do on desktop view? Thanks!
Good point with this Rob!
Currently slider takes 100% of the height of the device, however, it doesn't subtract header height.
I believe I made it this way, so after scrolling below header you could have full height slider. But I agree with you, that this doesn't look good in real life scenario - your page :-)
I will look for a fix for next update :-)
Have a great week!
