Hello! i'm having problems with this page:
http://www.rebeccarinaldi.it/albums/i can't manage to:
1. leave the header always visibie
2. change black background to light gray
3. change url name
4. remove the home page slide show from the list
can you help me out?
thanks,
rebecca
You don't know how to do all these things or it is just not working?
If it is not working, then please make sure that you have disabled cache/optimization plugin while doing these changes.
in this page http://www.rebeccarinaldi.it/albums/ and all the inner galleries... i would want the header to be always visible ( not only on hover) and with white bg...
So we need to change colors for the normal variant. Go and adjust colors in:
Appearance → Customize → Header Settings → Type, variant, background
Appearance → Customize → Header Settings → Main Menu
Appearance → Customize → Header Settings → Tools icons.
Could you tell me more what do you mean by that?
Edit your home page album and in album options https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-options/ look for option Albums list -> Exclude from Albums list page.
Hope that helps.
even do you have a sudggested plugin for intagram feed visualization?
can you make me a shortcode for "type of request" 1.shooting info/quotation 2.design service info/quotation 3. collaboration
thanks,
rebecca
Not really. Use what feels best for your needs.
Go to WpFroms in admin area and edit your form to what you need :-)
I believe you want to create form for clients. You can also prepare it in WPForms and next add it to your page.
