Hi Air
It's been a while without having to stress you guys
But now I ran into a new problem that doesn't seem to make sense to me: When I set a section height to fit the height of the screen it works fine in desktop view.. as soon as I go into tablet or mobile view the background image disappears... any idea? You can look at it here:
https://lunique-foundation.org/lunique-foundation-home/Thanks for your help
Pascal
Are you sure that this section is not hidden on the mobiles?
Let's try with this first and check (similar to my example screenshot) how it looks in "Visibility section". Everything should be marked as unchecked.
Let me know what you have there
With regards
Thanks for the input.. unfortunately these settings were correct and the problem remains even if I go back and forth to save it again... any other inputs?
Pascal
Should be good now.
With Regards
But doesn't it seem weird that it doesn't work on mobiles? There's no mention of it while other things (for instance Fixed Scroll behavious is mentionned as not working on mobiles).. also there is no option for mobile in section height.. so it doesn't make sense to have it?
Thanks, Pascal
I never saw that because I always have been adding content to sections in this full height option
From what I see Fit Screen works fine on tablet view, so there is no need to add paddings there.
Or maybe you see something I don't see
Crazy things are going on
It must have been some kind of cache issue.. I already had experienced this in Elementor in other situations .. after clearing ache rebooting computer and restarting the browser I now also see the correct (the same) as you do..
Thanks for your help!
Pascal
