logo links to the home page of the site. When i want use another link i pase this code:
jQuery(window).load(function(){
jQuery(".sfm-logo > a").attr("href", "
http://your-url.com/");
but do you have any idea how can I link to different language versions?
For example, when I am on a German language version, the logo should link to home page german, not to my native Polish.
If you are making custom JavaScript solution, then you will have to somehow get the country code and add it at end of this link.
You can try to add this code
jQuery('html').attr('lang').substr(0,2)
- it retruns first 2 letters of language code.With kind regards.
