Hide main menu on one landing page?
in Rife Posts: 10
Is there a way to hide the main menu on one page only? (landing page for an
ad)
Does that need to be custom CSS then?
The page is:
http://sweetoliveweddings.com/ad-cincinnati-wedding-photographer-landing/
    Do you want to hide the whole vertical header or only the menu mart from it?
    Either way, custom CSS will be required.
    I will help you with it once you tell me which option you want.
  • The entire vertical header would be perfect.
    Please use this custom CSS:
    .page-id-11153 #header {
        display: none;
    .page-id-11153.header-vertical #mid {
        padding: 0;
  • thank you!
