this is the plugin: https://wordpress.org/plugins/pinterest-pin-it-button/ i thought it should add a "pin it" button to every image in the blog, and that i could add description, captions and hashtags to the images for pinterest serarch...
I don't think this plugin will work like that out of the box. What is more, it was not updated in 4 years. You should look for another plugin probably that is more actively developed:-)
1. What are the symptoms of it not working - what are you expecting it to do?
2. Link to the plugin will also be helpful.
WIth kind regards.
