Hi there,
I chose for each album the presentation option in the form of "bricks" and a small cross is displayed on each image of my album. Great, it catches the eye.
I also linked a link to each media I added to the album. Each media is associated with a "works".
The problem is that when a visitor clicks on the cross (or on a horizontal band about 10 pixels), the link does not work. This link works normally when the user clicks anywhere else on the image.
I would like to remove this non-clickable headband but still keep the cross that catches the eye.
In attachment, you will see the banner (in blue) which is non-clickable, which is not at all intuitive since the cross is made to attract the eye.Code HTLM1<div class="icon a13ico-plus">
2 : : before
3 </div>
CSS code.variant-overlay .object-item .icon, .variant-under .object-item .icon {
font-size: 44px;
color: #fff;
text-align: center;
position: absolute;
z-index: 2;
top: 50%;
left: 0;
width: 100%;
opacity: 0;
transition: opacity .3s;
-webkit-transform: translateY(-50%);
-ms-transform: translateY(-50%);
You can test directly on my website :
http://pierrick-gandolfo-sculpteur.fr/album/accueil/Thanks you for your help ;
Best regards,
Benjamin
I see that we have to put a layer of the link above the plus. To do it add such custom CSS: I will also fix it for the next update. Thanks for reporting this!
Best regards,
Benjamin
Best regards !
