Is there any way to make text flow or wrap around an image within a column? I've tried to imitate text wrapping with various column configurations, but that doesn't survive well in a responsive environment (If I make it work for a monitor, it looks awful on a phone).
On a related subject, can text be made to flow from one text box to another, so that if the box is re-scaled, the breakpoint between boxes would be adjusted automaticallyks!
Many thanks!
I believe you could insert image normally in a text editor and then align it in left/right - text should then flow around.
Could you show me with the live link what you got currently?
