Hi there. I use the Rife Pro theme (child version). I have Google tag manager installed on my site. After updating the rife theme I loose the tag manger snippet and therefore important tracking information.
How do I prevent this from happening again ?
There's no header funnction file to edit in the child theme..
Andy
You have to copy modified file or function( https://rifetheme.com/help/docs/modifications-of-theme/changing-theme-functions/ ) to the child theme, to keep your modifications between updates.
So if you modified file rife/header.php you have to copy it to rife-child-theme/header.php
Hope that helps.
