Hi Air
Still having fun using rife and element or and have less an dless issues.
But no zero
I am using an svg logo in the header (dark variant for the page) and another svg logo in the sticky variant. Unfortunately it always uses only the logo in "logo" and not the one set in the variant.. any idea?
Link:
https://beta.baselathome.chThanks, Pascal
Thought it was a cache issue.. but no.. still an "real" issue
Please check that you have enabled logo switching in header color variants :
Appearance → Customize → Header Settings → Logo → Use logos from header variants.
For me, your normal logo, dark and sticky all look the same.
Do they differ at all in colors?
Or maybe you were changing the color of these parts with CSS? If you like I can help you use just one SVG and change colors with CSS.
This way you will only have to use 1 logo:-)
Thanks, Pascal
The issue is that each SVG contains CSS, and each logo overrides previous rules added by the previous logo. If each logo had different classes for paths it will work fine. Now each logo has
.cls-1
and try to style it.Using inline SVGs is tricky :-)
I will switch you to one logo with color to variants done in CSS.
I will update you soon :-)
Thanks very much for your appreciated and fast help!
SVGs are tricky, but that is why you got us to help if something is getting confusing :-)
Have a great weekend Pascal :-)
Thanks, Pascal
If you will open SVG in the text editor you will see all its markup.
And CSS is added in Custom CSS: Appearance → Customize → Custom CSS.
