Blog Page & Single Post Images
in Rife Posts: 87
Hi
Hope your good. I have tried all the customize settings for the blog page but cant find where to remove/change the default theme image for the blog page template
https://metta3.com/blog/
Also Single Post Featured Image is Full Width and Very Dark - again cant find where to change this setting. Is it possible to not have a dark overlay>
I think the Gruby blog template would look better - please can you let me know how to make the changes to look like Gruby thanks
Im not going to build a new template yet.
    Hi again - what I would like to do is have a centre justified? Blog post with images that match the width - exactly like you can see here
    https://kinsta.com/blog/err_connection_refused/
    I cant seem to remove the top single post image and also the blog listing page image - thanks
    The final post is here - see the duplicate image - this is not set as a featured image so I guess the template is setting this??
    https://metta3.com/how-to-market-on-social-media-in-2019-guide/
    Hi again - have worked out how to turn off the blog page image but this turns off all the content - I just want to have no image but do want to have a title written there - how can I do this please
    thanks
    I am not sure which questions are current and which not as you are mixing so many things here. I will try to answer the last comment.
    MyMetta said: have worked out how to turn off the blog page image but this turns off all the content - I just want to have no image but do want to have a title written there - how can I do this please
    You probably mean title bar for the blog here, right?
    Go to Customizing ▸ Blog settings ▸ Posts list - Title bar.
    There enable it and change the background image and then remove it, as maybe it got stuck.
    Also set Overlay color, and you should be fine.
    Let me know which question you also want us to answer currently.
  • edited April 2019 Posts: 87
    Hi Thanks!
    Its quite confusing :)
    What do all the header hide content things do?
    Okay I have set up the blog page for now - 3 little things left
    1. The scrolling shows white blocks above footer - see screenshot
    2. Single Post - Shows the first image above the post title - so it repeats the first image. No featured image is set. Which setting controls this please
    See live post here https://metta3.com/how-to-market-on-social-media-in-2019-guide/
    3. Single Post Layout - the content width is very wide - how do you control this and what size is the width for images. I would like to get it to look like this layout
    https://kinsta.com/blog/http-to-https/
    4. Breadcrumbs dont show on the blog page but are enabled for single post. Can you enable these for the blog landing page?
    Thanks a lot!
    1920 x 1080 - 284K
    Post edited by MyMetta on
    MyMetta said: What do all the header hide content things do?
    Do you mean option Hide content under header? Please read about it here https://rifetheme.com/help/docs/content-management/pages/pages-options/
    MyMetta said: The scrolling shows white blocks above footer
    In this case we will have to add backgorund for blog to hide parallax footer. Please add such custom CSS:
    .blog #mid {
        background: #fff;
    MyMetta said: Single Post - Shows the first image above the post title - so it repeats the first image. No featured image is set. Which setting controls this please
    It is featured image. You can disable it in Customizing ▸ Blog settings ▸ Single post ▸ Display post Media.
    MyMetta said: Single Post Layout - the content width is very wide - how do you control this and what size is the width for images. I would like to get it to look like this layout
    Available layout are in Customizing ▸ Blog settings ▸ Single post ▸ Content Layout. We don't have such narrow one.
    However, first thing you should do is rise font size of content, as it is pretty small in compare to Kinsta posts.
    You are currenlty using option "Full widht + fixed content". You can add such custom CSS to make it more narrow:
    .layout-full_fixed .content-limiter {
        max-width: 800px;
    MyMetta said: Breadcrumbs dont show on the blog page but are enabled for single post. Can you enable these for the blog landing page?
    Go to: Customizing ▸ Blog settings▸ Posts list - Title bar ▸ Breadcrumbs
    Hope now everything will be better.
    Happy Easter!
