Discussions
Categories
Home
PhotoProof
Portrait Image Pop-up In Scroller Cutting Off Height
ronaldback40
May 2019
in
PhotoProof
I'm having issues with the scroller and portrait images when you click to expand. The portrait image is being cut off at the top and bottom.
What do you recommend to make the portrait pop-up so that the photo isn't cut off.
Ronald
Air
May 2019
Options how the opened photo will behave can be found while editing album → Album details → Album media → Fit images - after opening.
You can not have "pop" but no cut, as this impossible if the size of the container doesn't change ;-)
ronaldback40
May 2019
Thank you. That worked perfectly.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
590
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
May 2019
ronaldback40
May 2019
Air
Discussions
Categories
Sign In
