I don't see usual page header/title area options and shop page not displaying correctly....
Hey Apollo Fam! I've spent quite a bit of time trying to figure out issue but I can't. Normally there are header/title options at bottom of each page but they aren't there now (and Rife, Elementor all up to latest versions as is WP)
and also I can't edit in Elementor and when click 'Safe Mode' the Elementor icon on left just keeps spinning and I can't edit the shop page at all (need to add padding above and below as header is covering products. The site was build a while ago with Rife and Elementor and only having issues now that added Shop and Products. https://marikaberoukas.com/
As much as I luv Elementor I run across issues quite a bit where I can't edit (using with other themes also) Really frustrating as you can't see any of the page content either way.
I only post in the forum when I've tried all I can to figure out issues, so Big UPS always for the help!
-Sterling
    As you can see on your first screenshot there is a notice "Theme options for this page can be found in Appearance -> Customize -> Shop(WooCommerce) settings."
    So go there to change those things.
    The shop page is not editable in Elementor, as this is a special type of page. You can recreate this page in Elementor Pro with use of their templates for WooCommerce.
    Hope this helps a little:-)
  • edited June 2019 Posts: 59
    YO AIR!
    Hmmmm so odd those Rife page style options are showing now which looks to have fixed overlapping header over content issue, ok cool
    and great idea about Elementor Pro, I have the 1000 use Pro subscription so easy to add to anyone's site, just did that and created a nice shop page https://marikaberoukas.com/shop-presets (best to not set in woocommerce Shop page as you are stuck w their styling, but use Pro products widget)
    https://marikaberoukas.com/product/the-diana-mobile-lightroom-preset/
    I had accessed the customize/shop(woo) page before posting a support message here but didn't seem to have the fixes I needed but now that the Rife page options are showing at the bottom of each page there is proper top and bottom page padding showings so
    ALL GOOD!!
    Just went live with my new hosting site redesign if interested https://TheHostingNinja.com
    and really into After Effects motion graphics lately, new page for https://thewebstylist.com/motion-graphics/
    BEST to you Air and Rife and Apollo13 Summer 2019 all forward!
    -Sterling
    #TheWebStylist
    Post edited by TheWebStylist on
    Hey Sterling :-)
    Those options showed up when you have created a new page for products instead of the default one, that WooCommerce reserved.
    Great, that is all working out for you!
    Keep up your great energy!
