Hi all,
does anyone know how to properly integrate an Adobe font into PhotoProof? I know how to integrte the CSS code, but I get still the standard font and not the one I want to see on every page. I also checked the dropdown lists of possible font items. But my font (fright-neo-pro) is not listed.
Thanks for any help!
1. Where have you placed fonts files for your custom font?
2. Could you share a link to your page where you tried to implement it? I will check what could be wrong.
But this seems to be not working as expected.
What is the name of the font that you are trying to use?
Please see this instruction on using Typekit fonts in theme https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/fonts-settings/#using-typekit-webfonts
However, if you want to use them with Elementor Pro, and it doesn't work, it would be good to ask Elementor team support.
