Here is my website www.healthwebdesign.com Could you tell me how to make a target blank on "Our Work"? When I click the picture, I want to open a new tab.
Hello! I followed your instruction with JavaScript by adding the provided code to "Simple Custom CSS and JS" plugin but it is only working when we click on the photo's title (text that overlay on top of the each photo). I wonder if are there any codes that, will work on both(title & outside)?
There is no such option for the works list. However, you could insert normal Album instead with shortcode https://rifetheme.com/apollo13-framework/docs/content-management/shortcodes/gallery/ and in each photo, mark to open in a new window https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-media/.
Another idea would be to use custom JavaScript plugin like this one https://wordpress.org/plugins/custom-javascript-editor/ and insert such JavaScript(Appearance → Custom JavaScript) With kind regards.
Thank you
I see that currently, you have some JavaScript errors on your website. Not sure where they are coming from. Might be some plugin.
Anyway, this is prohibiting script to work at all. Try clearing cache and check do you have the same issue.
