one more question. I had set up the password protected page now and I like it very much but - the field for entering the password is outside of the "content" way too down, how can I move it up, just right under the arrows preferably?
However, for this to work on every resolution you will have to make your Row/section in Elementor more fixed height then now. Like, for example, make it 400px high.
There is a problem with that to be honest as this has to be outside of content due to how this is created.
However, I can help you bring it up with custom CSS if you would send me a link to such an album. You can do it here, or by a private message.
You could try to use such custom CSS: However, for this to work on every resolution you will have to make your Row/section in Elementor more fixed height then now. Like, for example, make it 400px high.
If you have edited imported page, you can revert back by using Revisions tab in Elementor while editing page https://docs.elementor.com/article/104-history
