This is part of the lightbox that is not our creation. So by overwriting this file you are risking losing your change on theme update.
However, now I see they changed this. In the past, it was a separate file that you could edit, but now this is part of JavaScript, so this will be a painful task to do. However, you can try.
It is located in photoproof\js\light-gallery\js\lightgallery-all.js line ~3286, however, the theme is using a minified version of this file located in the same directory lightgallery-all.min.js.
If these sharing buttons come from AddToAny plugin, then I remember that is usually showed social buttons most popular for a particular visitor.
However, it seems they changed it in recent versions. You should be able to choose your services in Settings → AddToAny → Standard → Share Button
Sure, but please check my private message from yesterday.
/// please tell me where this file and i edit it myself ....
Good luck!
