Hello!
1. either "next" or "previous" icon are missing in some single album.
It seems happening randomly in different album and different language.
(but some works perfectly have both next/previous icon)
I disable "Navigate by categories" as I want it back to "ALL" category but not the corresponding category.
2. one of the album is used for the homepage (I enable "Exclude from the Albums list page"),
but there is the "next" icon on the last album on the album list, it will go to the album (homepage) when click. How to disable the "next" icon on that album?
here is the link of the album which should be the last one in the album list:
http://www.vpang.com/zh-hant/album/高級日本餐廳/Thanks a lot!
I have found that is happening here http://www.vpang.com/zh-hant/album/m展亭/ but it is fine as it is the first album on the list.
It also happens here http://www.vpang.com/zh-hant/album/高級日本餐廳/ and this one I don't know why.
Do you know of any other albums?
Have you used any plugin for rearranging albums order? This option only excludes album from listing on Albums lists, but not in next/prev navigation.
To make an album also excluded from this navigation would be pretty tricky.
Yes, many. I found that all are happening in the category of "INTERIORS"
English version:
http://www.vpang.com/album/my-harbour/
http://www.vpang.com/album/my-day/
http://www.vpang.com/album/my-wedding/
http://www.vpang.com/album/lumiere-cinema-complex/
http://www.vpang.com/album/on-hing-terrace/
http://www.vpang.com/album/robe-di-kappa-flagship-store/
http://www.vpang.com/album/brioni-at-landmark/
http://www.vpang.com/album/greater-china-culture-global-association-centre/
http://www.vpang.com/album/tiley-real-estate-headquarter/
Traditional Chinese version:
http://www.vpang.com/zh-hant/album/my-wedding婚紗專門店/
http://www.vpang.com/zh-hant/album/太古匯盧米埃影城/
http://www.vpang.com/zh-hant/album/新光戲院/
http://www.vpang.com/zh-hant/album/置地廣場義大利高級時裝店brioni/
http://www.vpang.com/zh-hant/album/大中華文化全球協會/
http://www.vpang.com/zh-hant/album/天利地產辦公總部及會所/
Simplified Chinese version:
http://www.vpang.com/zh-hans/album/啟德遊輪碼頭餐廳設計/
http://www.vpang.com/zh-hans/album/my-day/
http://www.vpang.com/zh-hans/album/my-wedding婚纱专门店/
http://www.vpang.com/zh-hans/album/太古汇卢米埃影城/
http://www.vpang.com/zh-hans/album/安庆大厦/
http://www.vpang.com/zh-hans/album/时尚休闲便服robe-di-kappa连锁时装店/
http://www.vpang.com/zh-hans/album/置地广场意大利高级时装店brioni/
Yes, Category Order and Taxonomy Terms Order
https://wordpress.org/plugins/taxonomy-terms-order/
Any other way to create the homepage? Can create the slider with elementor instead of using album?
Many thanks!!
Yes, you could use one of the widgets of Elementor to make it, if you really need to remove this album from the navigation. However, it will probably look different than now.
Let's first slove issue with the navigation, and later I will try to help you with code change to exclude this album from the navigation.
I found that it works normally if I enable "Navigate by categories".
is it a hint?
Thanks for your help.
I have logged into your installation and tried various things.
I have found out that if I disable "Post Types Order" plugin, then it works well.
On all albums, there are both arrows then.
I am not sure if this is a conflict between this plugin and WPML, or just something to fully set.
However, if you decide to disable this plugin then you can change order or albums by changing in each album the publish date.
I have tried this trial but couldn't find the reason why it is better.
Thank you! but if disable the plugin, is there any way to customize the category order?
http://www.vpang.com/projects/
We want : Architecture > Planning > Interiors
instead of Architecture > Interiors > Planning
Thanks a lot!
I have another problem with the "To top button" icon. It cannot be shown.
(I have updated the icon library in elementor, and then found this issue)
please see attached.
Many thanks!!
So you will have to create new category specially for this album. Probably best would be to create such a category in each language.
Next, we need IDs of those categories, so we could exclude them from the navigation.
IDs you will get while editing category. Please see below screenshot:
Next, we need to edit theme code a bit. Go to advance\utilities\cpt-album.php line ~85 and change this code: to: Same we will do in line ~94. Change this: to .
Those numbers
136,137,138are IDs of your categories that you will create, so you will have to edit those to your values.Good luck with this change.
Once you get this working you can move this change to the child theme.
Thank you so much!!!
editing the code is quite difficult for me, I've tried once but failed....will try again.
The IDs are 65, 66, 67
A thousand thanks!!!
Now assign your home albums in each language to the proper category. I have done it already for English.
It works perfectly now.
Grateful for your help!!
I got another issue: this new category should not show up, how to remove from the filter on the album list?
Thank you!
I think that the best way would be to hide it with custom CSS in this situation.
Try such custom CSS: With kind regards.
Thank you sooo much!!
